Super H electrical
Posted by aaachris on June 24, 2008 at 07:36:12 from (216.13.140.10):
I have the tractor charging and running on 6v pos ground. The regulator and coil is 6 volt also. I was burning up points on a regular basis so I added a ballest resistor to the coil primary circuit. I should note the coil and regulator were purchased from TSC and the ballest resistor was purchased from autozone. Problem is, as soon as i installed the resistor, im blowing a small amount black out the exhaust and its a bit hard to start. When I bypass the resistor, it fires right up and no black smoke, runs perfect. Do I have the incorrect resistor?
Any thoughts??
Thanks!
