if the fuel supply to the carb is good, next time it happens,remove the drain plug on the carb bowl and see how much of a fuel flow you get. if it emptys the bowl and stops, could be the float is hanging up. some things to check, see if the float is rubbing the side of the carb bowl, see if the shaft that holds the float in is staying on the posts, or sliiping out. check the bowl gasket to see if it is sticking too far into the carb and catching the float. if all these check out, remove the fuel line at the carb, see if there is a screen filter in the fitting and check for debris.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
