'49 Super-A carburetor problem
Posted by Alfred White on June 24, 2008 at 08:41:27 from (71.114.57.143):
the engine will idle down and cut off after a few minutes of use. I suspect it is a problem with the float in the carburetor. the only way to get the engine to start again is to drain the carburetor and tap it a bit with a wrench, as if to dislodge the float. this is a recurring problem and I would appreciate any insight you could give me to help.
