Posted by John T on June 24, 2008 at 09:07:34 from (66.244.97.31):
In Reply to: Super H electrical posted by aaachris on June 24, 2008 at 07:36:12:
My best guess just sittin here in the dark is a bad, or not grounded, or not wired to points, or an incorrect sized condensor. (I agree with Jim n Bob, dont use any ballast if its a 6 volt tractor n 6 volt coil)
If the condensor is too big the points could last a long time, if its too small (or dont have a good ground connection to distributor, insure that) the points will burn up prematurely
Toss the ballast n get the right condensor would be my first try. If thats not it n you suspect the coil, see if its primary resistance (between lil + and - terminals) is around 1.2 to under 2 ohms or so Id expect for a 6 volt coil.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
