Re: '49 Super-A carburetor problem
Posted by RustyFarmall on June 24, 2008 at 09:21:02 from (209.152.78.71):
In Reply to: '49 Super-A carburetor problem posted by Alfred White on June 24, 2008 at 08:41:27:
If the tractor has been sitting for any length of time, the gas in the carb has turned to varnish and cause the needle valve to become sticky. Tapping on the carb will loosen it up a bit, but only temporarily. It is also quite possible that the hinge pin for the float has become sticky and the float cannot drop as needed. Probably your best option at this time to get a can of aerosol carb cleaner, take the carb apart and clean the needle valve and seat, as well as the float and the hinge pin. Probably will not need a complete rebuild, but you probably will need a new gasket for in between the top and bottom carb halves.
