I understand how it works but not well enough to explain to someone else. The pinion gears are splined on output shafts but turn freely on pinion pin. If you jack both wheels off ground and turn them with engine through driveshaft they will turn in opposite directions (at least on car or truck never tried it on tractor). When going straight ahead assuming tires are same diameter and one is not slipping on ground the pinion gears do stay in fixed position and turn as if they were locked on pinion shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
