Re: Farmall A
Posted by HENRY E NC on June 26, 2008 at 08:24:28 from (216.119.6.214):
In Reply to: Re: Farmall A posted by Brownie 450 on June 26, 2008 at 07:51:51:
An
A is a nonpressurised thermosiphon system that uses convection to cool. Water at the top of the radiator should be lots hotter than at the bottom. Farnmall Super A" 's had water pumps on the in later years. If your is a true A it will not have a water pump unless added as aftermarket. Maybe you are just filling it too high. Also, maybe the radiator needs cleaning. Henry
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
