Re: Farmall A
Posted by Brownie 450 on June 26, 2008 at 07:51:51 from (216.51.158.151):
In Reply to: Farmall A posted by RHill-CO on June 26, 2008 at 07:42:41:
Ours wasn't a pressurized system. Maybe some of the later ones had pressure system---but I don't believe many if any did. You might make sure that the fan belt is tight enough & the radiator is clean for maximum cooling.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
