Re: Farmall A
Posted by RHill-CO on June 26, 2008 at 11:24:02 from (65.121.44.78):
In Reply to: Re: Farmall A posted by Brownie 450 on June 26, 2008 at 07:51:51:
The rad-cap does look like a gas-cap. After a 1/2 day of hard mowing the water level is down below the core. So suppose with the thermosyphon system I must not be getting enough gravity flow and therefore the core may need cleaned.
Thanks guys for the information.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
