Re: connect for fuel shutoff solenoid
Posted by hicksdale on June 26, 2008 at 17:58:44 from (74.36.247.188):
In Reply to: connect for fuel shutoff solenoid posted by hicksdale on June 26, 2008 at 17:34:29:
Bob M
Thanks for the reply. If I take the ignition switch out, will it show the Ign position?
What happens if it were connected to the solenoid post that is connected to the coil?
How can I make sure I have the right post on the starter solenoid? It will be easier to hook there as apposed to the ign switch which will be hard to get to? Thanks. DH
