Re: How tight should the motor be after a rebuild?
Posted by old on June 27, 2008 at 07:55:32 from (4.244.90.48):
In Reply to: How tight should the motor be after a rebuild? posted by LeonOk on June 27, 2008 at 07:27:58:
As Ron says and also. Did you use a good lube on ALL the parts when you put it together?? If you didn't then thats part of the problem. But yes when you install new bearings etc they can/will be tight till they have been run and things brake in a bit
