How tight should the motor be after a rebuild?
Posted by LeonOk on June 27, 2008 at 07:27:58 from (199.83.40.36):
How tight should and motor be after a rebuild. I am in the process of rebuilding an F-20 with new rings and resurfaced rod bearings. The rod bearings all have 3 thousands clearance. The motor will turn fairly easily with a pry bar until I tighten the last rod bearing—it doesn’t matter which one is last. After tightening the last rod bearing the motor tightens up quite a bit. I can still rotate the crank one full revolution but it takes a lot more effort. Is this normal or too tight? Thanks
