Re: How tight should the motor be after a rebuild?
Posted by F-Dean on June 27, 2008 at 11:58:11 from (12.74.46.95):
In Reply to: How tight should the motor be after a rebuild? posted by LeonOk on June 27, 2008 at 07:27:58:
I use .005 on my F-20s. Be sure to lube everything when you put it together for the last time. I use automatic transmission fluid when making the last assembly prior to putting the cotter pins in. Your F-20 will probably turn less than 1,000 rpm so it is not as critical at a higher rpm engine.
