Re: How tight should the motor be after a rebuild?
Posted by scott rukke on June 27, 2008 at 12:34:36 from (67.183.230.71):
In Reply to: How tight should the motor be after a rebuild? posted by LeonOk on June 27, 2008 at 07:27:58:
Use Plastigage. They sell it at most auto parts stores. Put a piece on the crank journal, tighten it down and then take it off and measure the width of the crushed plastigage against the measurements on the package. It will give you accurate clearances.
I just rebuilt an F-20 and using had to add a couple shims to get the clearance right. I set the clearance at about .005.
