Farmall Tractors Discussion Board
Re: 560 Torque
Posted by Milan H. Dilworth on December 19, 1998 at 09:16:06:
In Reply to: 560 Torque posted by Steve on December 17, 1998 at 18:57:05:
The noise could be from either the DD throwout bearing, or the TA planet gears & bearings. The planetary repair is a much bigger job. I'd suggest pulling the drain plug at the rearend to check for moisture, and also the center plug (at the bottom of the rear split area) to check for metal bits. The throwout bearing is in a dry compartment. The planetary can be exprensive to repair.
Post a Followup
: Re: Re: 560 Torque
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
