Re: Super H Seat Shock Absorber Question
Posted by Haas on June 27, 2008 at 14:03:46 from (12.65.12.3):
In Reply to: Super H Seat Shock Absorber Question posted by Red Mist on June 27, 2008 at 11:56:20:
The seat mounting parts diagram only shows the bolt and the rubber bushings. The bolt, I believe is a shoulder bolt. Perhaps someone jury rigged the thing using some bushings when the shoulder bolt was shot. I think the new shock usually comes with the rubber bushings. I suggest you get a new seat spring while you are into it. I've had folks complain that their seat was bottoming out saying they needed a new shock to fix it. If the seat is bottoming out, the real problem is likely the spring although the shock may be bad too.
