Re: Super H Seat Shock Absorber Question
Posted by GordoSD on June 27, 2008 at 16:35:44 from (66.115.200.140):
In Reply to: Super H Seat Shock Absorber Question posted by Red Mist on June 27, 2008 at 11:56:20:
I went out and looked at my SuperH Stage II. That jury rigger was here in SD too! Mine has the two spacers in there. They appear to be about 5/8 inches wide.
The shock is there simply to take the recoil out of the spring. So you don't get the pogo stick effect. A new shock won't make the spring compress less. You might want to try a set of those coil spring spacers in your seat spring. Back in 1954 there weren't too many 300 lb farmers.
IH did make a heavy duty spring, recommended for foperators over 200 pounds.
Gordo
