Re: How tight should the motor be after a rebuild?
Posted by steelfronts on June 27, 2008 at 19:17:55 from (24.236.150.155):
In Reply to: How tight should the motor be after a rebuild? posted by LeonOk on June 27, 2008 at 07:27:58:
In my experience with F20s if the crank isn't ground you will find the journals to be oblong from the thousands of hours of being pounded on from the top an bottom. Your new rod bearings may be tight on the side.Chec the roundness of your crankshaft if it is in fact round and you do have .003 clearance you're fine. The after the fact test is after running it the first time shut it off an see if it will turn over hot.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
