Re: Super M hydraulic/transmission question
Posted by Bob M on July 01, 2008 at 09:31:55 from (151.190.254.108):
In Reply to: Re: Super M hydraulic/transmission question posted by RustyFarmall on July 01, 2008 at 08:55:44:
Or instead of adding more oil to a badly leaking belly pump, simply drop the dust cover then remove the drive coupling between the transmission and belly pump. Should only require only a minute or two, and you're gonna have to take it apart anyway...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
