Re: Super M hydraulic/transmission question
Posted by Owen Aaland on July 01, 2008 at 13:23:06 from (65.161.86.52):
In Reply to: Super M hydraulic/transmission question posted by Bob M on July 01, 2008 at 09:31:55:
Bob M said: (quoted from post at 09:31:55 07/01/08) Or instead of adding more oil to a badly leaking belly pump, simply drop the dust cover then remove the drive coupling between the transmission and belly pump. Should only require only a minute or two, and you're gonna have to take it apart anyway...
The coupler on an M will not come out without dropping the Lift-All pump. The H's have a coupler with sleeves and cotter pins. The M's use a short coupler with drive lugs at right angles that can only be removed when the pump is removed .
