Posted by Rad Redrunner on July 01, 2008 at 19:45:40 from (24.233.197.61):
Hey, Scotty, I think you saved me a bit of frustration by sharing your experience. I didn't have a 13/16" tappet wrench, but I did have a thin 13/16" adjustable metric wrench (as my dad called it) I had just bought in a set of pliars yesterday. (Funny, but I didn't really want the adjustable wrench at the time, but it turned out to be thinner than normal and perfect!) I didn't finish because I decided to go ahead and replace the fan belt while I'm in there, and I'll pick that up tomorrow. I don't think it's gonna be too bad to put back on, though.
HOWEVER, since I had laid the generator back to make room to work, I discovered that the arm from the governor that links it to the carb was extremely loose, with one inch slack travel (at the carb connecting rod). I noticed the throttle seeming loose and I mentioned before that the tractor stutters and dies if a load is put on it, so do I need a governor rebuild or is this one likely worn beyond repair? I know nothing about the governors on these tractors.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
[More Ads]
