Re: How do I get on board
Posted by Bob S. on July 04, 2008 at 21:10:56 from (68.113.237.237):
In Reply to: Re: How do I get on board posted by Andy Motteberg on July 04, 2008 at 20:57:26:
Hello
Thanks for reply, Ill give you the most important issue first. The seller must have had everything set up just right, I ran it and tested it for a short time before making a deal. The only leaks I found were at hyd cylinders. When I got her home and ran it a short time oil started leaking out of the oil pan at the pan gasket location. The oil is a little milky looking but not like it has a lot of water or anti freeze in it. I drained close to 2 qt out of the upper petcock. I ran it again today for a while and after 15 min it was leaking out of the pan gasket again. Any ideas. I dont want to burn it up as it runs very good for an old tractor.
Thanks Bob
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
