Re: How do I get on board
Posted by HENRY E NC on July 05, 2008 at 04:34:27 from (216.119.6.31):
In Reply to: Re: How do I get on board posted by Bob S. on July 04, 2008 at 21:10:56:
I have an M so maybe I can help some. As far as working on the tractor go to Binderbooks.com and buy a parts manual and a service manual. The steering is not an easy fix but take the grill off, hood also . T. The steering shaft goes into a round casting. Take the top off and then turn the whel. Watch the gears (worm gear and helical gear as you turn.If the horizontal gear moves back and for (front to back)then the bushings under it are worn out. If the worm gear moves a lot before the horizontal gear the chances are both gears are waorn. If you have a full round horizontal helical cut gear it can be rotated 180 degrees. I it is a quadrant gear you will need a used one. Used parts can be ordered thru many places. Email me and I will suggest several. Henry hmmh@dnet.net
