Re: Farmall H 12 volt conversion
Posted by old on July 05, 2008 at 12:53:28 from (4.244.186.37):
In Reply to: Re: Farmall H 12 volt conversion posted by Shahn on July 05, 2008 at 12:10:10:
Did you by chance make the mistake of hooking up 12 volts to the shut off terminal on the mag?? If you did then you probably fried the mag. But if your still getting spark from the mag but not getting to the plugs I would say you have a bad rotor or cap or the cap is wet or cracked
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
