Re: OT SMALL ENGINE ELECTRICAL
Posted by Owen Aaland on July 07, 2008 at 19:19:53 from (65.161.86.2):
In Reply to: OT SMALL ENGINE ELECTRICAL posted by JT on July 07, 2008 at 18:44:31:
JT said: (quoted from post at 18:44:31 07/07/08) 1st thing, you need 12vdc at the positive side of the coil, don't know why you would have a resistor in a Kohler engine. They are not required.
Do you have a plug wire that is wire cored and not a car plug wire?
you should have 12vdc at the neg side of coil every time the points close. You need a VOA meter to test it correctly, not a test light.
Jim
The voltage on the points side of the coil should drop to near zero volts when the points close. When they open you should get battery voltage,
