Re: What to use to cut off Axles on Farmall 450 ?
Posted by Farmer Bob on July 07, 2008 at 22:43:02 from (71.50.1.58):
In Reply to: What to use to cut off Axles on Farmall 450 ? posted by migraine on July 07, 2008 at 21:23:54:
A stand mounted electric band hacksaw should be the ticket to solve your problem. You may have to move the hub all the way in for clearance but I've used this method on a SC with exacting results. Carefully use a angle grinder to bevel slightly the outer circumference of the newly cut axle and then center punch the center of the end of the axle and drill a 1/4" hole about 1/4" deep. Using a pointed reamer, make the original bevel in the center of the end of the cut off axle. A little paint applied and shazam! Even the correct police will never notice. G'luck!
