Re: What to use to cut off Axles on Farmall 450 ?
Posted by CNKS on July 08, 2008 at 17:31:25 from (216.144.104.128):
In Reply to: Re: What to use to cut off Axles on Farmall 450 ? posted by Farmer Bob on July 07, 2008 at 22:43:02:
Correct police (of which I am not a member) will not like the paint, as the axles were not painted at the factory.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
