Early M hydraulic problem
Posted by chris klein on July 10, 2008 at 13:36:03 from (67.140.83.28):
I am adding a 3 point on an early M using the belly pump to feed the Valve. I have two fittings on the left and one on the right but all 3 are pressurized when you engage the pump. I need to know where the return line goes because I have had 2 people tell me that it is the fitting on the right but if I use that one the system just locks pressure on and it will not move the cylinder until the pump is disengaged. If I cap that line off and run the return into the fill tube everything works fine. Any information would be greatly appreciated.
