all three supply hydraulic pressure, the rear was for a rear mount cultivator. there was a restrictor on the rear cultivator cylinder that delayed the rear drop of the cultivator. you can plumb your return line to either the fill pipe with a tee or the way i did mine was to use a tee in the lower drain plug on the pump. use one end of the tee for the return, a small pipe nipple in the center of the tee and cap the other end of the tee. that way you still have a drain plug. also, on the control rod for the pump, i welded a small section of 5/16 steel rod so it has a nub like the other one on the rod, position it so it will hold the rod in the full on position.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
