Re: Super C Carb issues
Posted by Joe Kimbriel on July 10, 2008 at 16:06:23 from (76.14.108.155):
In Reply to: Super C Carb issues posted by jake w on July 10, 2008 at 15:14:18:
How did it run before the rebuild? I'm an expert with Super C carbs if you want them to run with half choke. I can't imagine that it's the govenor. Disconnect it, twist the throttle and see what happends. Most likely its the main jet plugged. Try recleaning it.
