Posted by Barnheater on July 10, 2008 at 18:46:34 from (63.116.189.98):
In Reply to: F14 Carb Adjustments posted by Doug Steinbach on July 10, 2008 at 08:24:49:
If it won't run unless the choke is pulled out, there is no fuel flow. First pull the plug out of the bottom of the float bowl & turn on the gas. If it doesn't flow freely then there is a restriction somewhere from the tank to the carb. If it flows fine & full then its restricted inside the carb. Usually pretty simple to fix once you find the issue.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
