Re: F14 Carb Adjustments
Posted by Doug Steinbach on July 10, 2008 at 18:58:33 from (71.159.143.41):
In Reply to: Re: F14 Carb Adjustments posted by Barnheater on July 10, 2008 at 18:46:34:
I did in fact fix the starving fuel problem, 2 fold issue of carb and fuel pump.
Still hard to start though, it seems to flood very easy, and it used to not do that. I can't help but think I just don't have the carb set quite right, but I don't know what a good starting point is with the fuel mix. The tractor runs great once you get it started.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
