544 won't keep running and/or start
Posted by andy r on July 12, 2008 at 15:53:45 from (67.224.8.75):
I need some pointers on this problem. The old tractor was always dependable. Starts right up, idles good and has always stayed running. This past week it sat on the auger filling trucks. Once again it would start right up. Maybe it might hesitate off and on ... not too much out of ordinary. Well, after running the auger for a half and hour or so it would just quit. It would not start again for 15 to 20 minutes. Then it would start and run OK. Now it won't start. You can crank and crank on it and it won't start. Always seemed to have good fuel flow at the sediment bulb, through the fuel pump and out of the carb. when the fuel bowl screw was opened. Any ideas??? I didn't know if the coil and points might start to act up when they get hot??? Thanks. andy
