Re: 544 won't keep running and/or start
Posted by John G. Hasler on July 12, 2008 at 17:45:27 from (69.179.121.5):
In Reply to: 544 won't keep running and/or start posted by andy r on July 12, 2008 at 15:53:45:
See if the float or the float valve is stuck. Check the fuel shut-off solinoid. Check for clogged passages in the carburator.
