Dan, You have to remove the two bolts in image 96. Compress clutch disc by removing 3 bolts from pressure plate and insert into pressure plate holes to compress pressure plate. Wiggle out the drive gear assy. the main shaft can then be moved towards the front of tractor and removed. This works on SM so I hope this helps.
