Re: Farmall H - a bad pto project gone horribly wrong- pl...
Posted by mkirsch on July 14, 2008 at 05:14:40 from (64.80.108.52):
In Reply to: Farmall H - a bad pto project gone horribly wrong- plz help posted by M Lake on July 13, 2008 at 21:10:14:
You don't need to split the tractor. Put 'er back together at the bell housing.
If you can't get the bolts out of the clutch shaft, even by twisting, thread the nuts about halfway back on and give them a good sharp rap or two with a small hammer. They ought to pop right out.
My H's pressure plate didn't have anywhere to put bolts to release the pressure, and neither did the new one but it wasn't a problem. I just slowly released the bolts in order as Dad rolled the engine over. The pressure plate was completely loose long before the bolts were out, and the new plate went back in the same way.
Hardest part is getting that front shaft out. You'll swear there's no way it'll ever come out, but just keep trying different angles and shifting the pressure plate and clutch around. It only comes out in one position, but it does come out, and when it does, it slides right by, not even tight.
