When you get the tapered bolts out of the clutch coupling (four of them, fit like tie rod ends)you may have to pull the clutch completely out in order to pull part #18 off of the trannmision shaft.I used a two bolt puller on #18 it won't pull with your hands. Your seal behind #18 is leaking, fix it now if it hasn't already screwed your clutch plate. Good luck ,old tractors sure make your hands black :)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
