Re: Farmall H bottomed out
Posted by Mike Farmer on July 14, 2008 at 07:17:19 from (86.31.84.127):
In Reply to: Farmall H bottomed out posted by :RIVIR on July 14, 2008 at 05:29:41:
If you already have the conrod bearing off check if you have driven it down so far that the bottom piston ring is out of cylinder. If so you will probably have to break the ring off for it to re-enter the bore. Plenty of oil, block of hard wood and a big hammer and it should move fairly easily. Yep I know there are exceptions. MTF
