Posted by Dean_Wheeler on July 14, 2008 at 13:03:54 from (136.181.195.11):
I have a farmall H with a distributor driven hydraulic pump which utilizes the lift-all as a resevoir. If I need to plumb an additional return back into the resevoir, can I do so through the original "pressure port" elbows? Or do I have to T into the current return which goes in the bottom of the lift-all?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
