Re: Farmall H Liftall resevoir
Posted by Nebraska kirk on July 14, 2008 at 15:19:24 from (75.88.86.241):
In Reply to: Farmall H Liftall resevoir posted by Dean_Wheeler on July 14, 2008 at 13:03:54:
If the pump has been removed from the resevoir, then you can run the return to the original pressure ports, otherwise just T into your current return.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
