Re: Internationl 2444 running problems
Posted by georgeky on July 14, 2008 at 19:05:42 from (205.188.116.73):
In Reply to: Internationl 2444 running problems posted by TexOnt on July 14, 2008 at 18:02:05:
Maybe you have a little crud in your tank that move over the outlet and is cutting of your fuel flow. May even be a float adjustment issue. Is your float sinking. I had one on my SC develop a microscopic hole this spring, and it acted much the same way as the float sank. Might try a new condensor, but most I had go bad were dead and the tractor just quit and would not start again. The cheap gas(Hehehe!) is fine in them.
