Thanks Georgeky for the tip. I was planning on blowing air back up through the line to the tank tomorrow and see if it runs longer before quitting. Then checking the sediment bowl to see if it is not filling up fully when it quits. Also going to check if there is a good flow from the fuel pump to the carb. Maybe if there is crud in the tank I can put the line up inside the tank further from the bottom to stop it from plugging up. Yep cheap gas isn't it :-) Ours is 5.85 a Canadian gallon which is 4.91 a USA gallon for regular. The premium which is only 91 octane rating is out of site here...6.50 a Candian gallon or 5.48 a USA gallon. No way I want to have to start using premium in it. If I had to I would use regular and add octane boost I think.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
