Re: Replacement coil - for a Farmall Super MTA
Posted by Bob M on July 16, 2008 at 05:13:59 from (151.190.254.108):
In Reply to: Replacement coil - for a Farmall Super MTA posted by Keith in Md on July 16, 2008 at 04:20:09:
Keith - With that 3 ohm coil you don't need the ballast resistor! (A coil requiring ballast for 12 volts will show a primary resistance of about 1.6 ohms or so.)
Assuming your tractor is now negative ground, the supply from the ign switch should go to the coil +. The coil - terminal goes to the points terminal on the distributor.
Good luck to you and your stepdad!
