Re: H Trouble Starting
Posted by El Toro on July 19, 2008 at 08:15:55 from (205.188.116.73):
In Reply to: H Trouble Starting posted by Clarkbug on July 19, 2008 at 07:43:24:
You need to sell if there's fire to the sparkplugs
when cranking. Pull off one the plug wires and hold it about 1/4" away from the plug while makes an attempt to start the engine. If its a weak spark could be the impulse coupling isn't working.
Listen for the snapping action of the impulse coupling. If its ok could be a weak coil.
If there's no fire when cranking clean the points with some 320 wet or dry. Make sure the point gap is set at .013". If there's still no fire replace the condenser then check again for fire.
Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
