H Trouble Starting
Posted by Clarkbug on July 19, 2008 at 07:43:24 from (72.66.39.171):
Hello All.
My '44 H with the magneto ignition was giving me some problems starting this past weekend, and Im not sure why.
Prior to this, it always started right up, no issues at all, and purred like a kitten once she warmed up a little.
This time I went to start it, and it turned over fine, but didnt even give the hint that it wanted to start. Not a stumble or anything. I had to jump it from my other 6v H, and then it finally caught, and ran great. Once it had started once, there werent any problems starting it again.
My father went to move the H yesterday, and it wouldnt start again for some reason.
There is good fuel flow, so that leads me to think its spark. What on this magneto could have changed so recently that would make it not want to start?
Any help is much appreciated!!!
~Bug
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
