Re: Brake seal on Farmall H?
Posted by Nebraska kirk on July 19, 2008 at 20:35:31 from (98.16.173.12):
In Reply to: Brake seal on Farmall H? posted by Pairodox on July 19, 2008 at 17:38:38:
There is a large oil seal in there, it seals against the hub of the brake drum. You will have to pry, hammer, chisel it out :-)then replace with a new one, any good automotive parts store can cross the number on the old seal and get you a new one. The old seal is about 3/4 inch thick while a new one will be about half that thickness, that is not an issue, tap the seal in until it is flush with the outside of it"s recess. The cork washer keeps oil from leaking out between the splines.
