Brake seal on Farmall H?
Posted by Pairodox on July 19, 2008 at 17:38:38 from (72.79.157.14):
I removed the brake drums from my 1942 Farmall H and found oil leaking from the nearby transmission. How do I repair this? I can't see a seal of any sort. Does the splined drum act as a seal? And what do you do if it's leaking? I noticed a cork washer on the bolt which holds the drum fast ... is this all there is acting to keep the tranny oil from leaking out?
