Re: Cub Charging problems
Posted by Janicholson on July 20, 2008 at 14:34:38 from (66.173.50.72):
In Reply to: Cub Charging problems posted by John M on July 20, 2008 at 09:01:50:
With it running at 1/2 throttle or more, use a piece of copper wire to short the F terminal on the genny to ground. This makes it charge full power. If the amp gauge still goes to - then the genny has issues,
or the cutout in the regulator is opening up. Putting the third brush closer to the other one makes it charge more. John T charging system analysis document in the search for area will also help a bunch, JimN
