Re: '45 M - hydraulics low?
Posted by RustyFarmall on July 20, 2008 at 16:45:28 from (209.152.78.71):
In Reply to: '45 M - hydraulics low? posted by Kevin Statz on July 20, 2008 at 10:30:52:
Your loader is a McCormick #30 or #31. It should raise to about 8 feet or so. It is also supposed to have hoses attached to the front/top of the cylinders and the other end of those hoses should be connected to the belly pump fill pipe. The front part of those loader cylinders is a reservoir for hydraulic oil. As the loader is raised, the oil in the cylinder reservoir is pushed into the belly pump reservoir, which gives you more oil available for raising the loader.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
