Re: '45 M - hydraulics low?
Posted by Kevin Statz on July 20, 2008 at 17:00:43 from (216.176.159.13):
In Reply to: Re: '45 M - hydraulics low? posted by RustyFarmall on July 20, 2008 at 16:45:28:
That helps!
I was thinking it was a strange setup. I did notice a bit of fluid leaking from the front caps on the end of the cylinders. Guy I bought it from told me they were vents and had to be loose to allow pressure off. Some leakage because it was old.
So I should put a return line on each of them back to the reservoir. Just gotta figure out which of the two outlets on each side of the tractor are the fill pipes.
Thanks!
~Kevin
